Guys, What Tool Did U Use To...
strikeeagle
...remove your PM brake pressure switch. I believe in the right tool, but I'll be damned if I can find a 1-1/2" sending unit socket. And an open end wrench is so damned long I'm afraid I won't be able to swing it. Is this damned switch hand tight, or what? What the hell did you use on it?
Thanks for your ideas...
:D
:D
Umm..channel locks :)
1. The 'Ugly' method works perfectly, provided you can control your squeeze power.:cool:
2. I wonder if the $5 GM oil pressure socket wouldn't slip right over that baby?
HTH
Jim
I believe that the oil pressure socket works. I will bring mine to the GM power train show Saturday, Hope to see you there.:cool:
John Macpherson
Ugly, Jim, uglyyyyyyyyyy...
Anybody else?
:D
Yea but it aint that tight. Once you crack it loose, it comes out by hand. Install is the same, run it down by hand then a little hrmmph with the channel locks. The O-ring seals it, not the threads
Worled for me 2 or 3 times.
The oil pressure switch 1-1/16, the brake pressure switch is 1-1/2...
See you Saturday, John...
:D
Powermaster brake switch 15-20 ft. lb.s.
Use your hands. ;)
Large adjustable or Robogrip might work. :)
