turbodave231
Moderator
 - May 24, 2001
On a recent build, I removed the valve covers after running the engine. I found that the pushrods were rubbing on the gaskets and in several spot were making small witness marks on the cover itself.
These are GN1 heads w/ T&D individual shaft rockers and GN1 valve covers
I corrected the situation by carefully marking the contact areas and grinding the valve covers. I RTV'd the gakets to the cover and then trimmed the gasket away using an razor knife. I'm glad I caught this before this engine got installed in the chassis.
