THIS is personal preference. I have used Permatex thread sealant with Teflon for MANY years with great success. Others HATE it! Some use Loctite , others use slicone. Which is better........blonds or red-heads?
I've used the permatex in the white tube (unsure of exact formula but I'll check) on a couple of engines, both studs and headbolts and haven't had any leaks. I do all my torqueing before it sets up and let it set awhile before I fire it.
I want the teflon to help "lube" the threads for a more uniform torque. If my water/cylinder block ever come close to 350*................I've got REAL problems, none of it being water leaking past the head bolts. :biggrin:
