Oh man..........How can I? do you need a set? (I have them) Do you need the torque (I can look it up for you) Did you invent a better set? (I might be interested) did you break one off inside the block? (BUMMER!!!) Do you need the thread pitch? (7/16-18) Can you re-use factroy bolts? (Yes, there is a service bulletin stating so) How many bolts do we use? (depends on if it's a stock block or StageII block) Do ARP head bolts work on the inside ends? (Yes, but you need to add another washer under the head) Anything else?
