buickGN3:16
- Jun 29, 2012
i want to order cometic head gaskets for my motor but i need to know the specs on the bore & thickness i need, the block is stock bore.
SignUp Now!1fast cobra, i see u are posting on the mobile app? I had it on my ipod touch4 & it had trouble logging in so i deleted it to re- download it & its gone from the app store, or do u think this is just an issue with apple devices?
Why do u suggest stock head gaskets for my application instead of cometics? i dont have alky but i run 110 mixed with my pump gas & can normally make 24 - 25 psi when My tt race chip is in
X2Myself and others with mild builds are running the Felpro 9441 PT gaskets or the Victor Reinz gaskets which are the "stock headgasket option" and have no head gasket related issues with 25+ psi of boost. Its all in the tune. If the tune is off and you run one of the "stock" head gaskets the fuse will blow before the motor. Cometics on the other hand can take more abuse and therefore instead of the "fuse" blowing you risk hurting the motor itself. What are your plans with the car? If you want to build a stock to mild motor, I would go with the 9441 PT. If your building a high hp motor or plan on beating the stock build for all she's worth, go with the cometics. Either way you decided to go, make sure everything is flat, clean, torqued and installed correctly.
