head gasket thickness question??? help
nitron
Please help me with this. I have a 109 block that has been decked i thin 10 thousands and i need to know what thickness gasket would i buy from cosmetic? Help please
I just want to keep my heads and intake aligned. I thought if the block is decked I o go with thicker head gaskets
I think the stock composite gasket is .040. Cometic makes a .051 thick MLS gasket, TA has them in thicknesses from .040 up to .120. Be sure your block and heads have a fine finish or you may have some coolant leak/usage issues. I used AC Delco stop leak tablets when I ran Cometics to solve the coolant use problem.
