headers stock
  • Thread starter Thread starter lalonde441
  • Start date Start date
L
lalonde441
Guest
can the stock headers be ported out to allow more flow? just curious guys.....also if so whats the best amount to port and what difference would it make? thank you.
Weld the pipes on the outside to the flange, port the inside a bit. Probably helps in the tens...
Headers
The headers LOOK small, but think about it. The exhaust in a Turbo Buick is running under substantial pressure, maybe as much as 30 psig. That compares to 1 or 2 psig in a normally aspirated engine. It means that the volume of exhaust gas is much smaller, even allowing for boosted intake flow. The smaller pipes keep velocity up, and pressure up, to drive the turbo. IF you put in bigger headers, you will lose low rpm boost. The guys with the really fast cars can tell you when headers are needed- my (almost stock) Buick never leaves the street, but I thought I would throw in some "theory".
ok so a waste of time then to do this. better off sticking with the stock units and welding them. thxs for the feedback.
