I got this heated O2 off ebay and email the guy I got it off of ....he told me to look it up....I ALWAYS look stuff up ...anyway here's a pic of it .......if you could please help.......
It plugs into one of the fan relays. If you don't mind waiting until this evening when I get home I can look at mine (I believe I have the same hookup) and I'll post how it's plugged in.
It goes in the fan relay on the drivers side of car, last one toward firewall. When you pull the plug from the bottom of this relay, it will be obvious where everything goes.
Thanks! I was going to jump in this morning. It plugs into the mentioned relay on the inboard 3 prongs (closest to powermaster), and the plug removed then plugs into the other connector that's part of your O2 harness.
