Nov 14, 2005 #1 H Hiwinds Member Joined Jan 21, 2004 Messages 171 How does the heater control valve hook up on a tta? It wasnt on mine when I bought it. Pics of under the hood would be nice. Thanks
Nov 14, 2005 #2 J Jan Larsson Active Member Joined Nov 22, 2001 Messages 2,151 If you mean the heater control valve found on the GN close to the firewall this is not on the TTA only on the GN
Nov 14, 2005 #3 H Hiwinds Member Joined Jan 21, 2004 Messages 171 Then how do you hook up the heater?
Nov 14, 2005 #4 3 3.8TransAM Member Joined Apr 8, 2004 Messages 325 Lower line on core goes to lower line on motor(is flat on engine) and upper line on core goes to the higher one on motor(sticks up on 90deg bend) later Jeremy
