CadillacPat
- Jun 4, 2009
Hello all on the Turbo Buick board!
Looking for info on the Vortec 4.3 on Google, I found a link with threads here.
I have a '99 Blazer of my daughters that I am replacing the original engine with one from an '03. There are a few differences, the main one being the '02's up don't have EGR. The other two being '99 having a year-only electric smog "secondary" pump and the other being different type of knock sensor. The knock sensor fix is easy as you just drill out the mounting hole to the older 1/4" pipe thread and use the older sensor. I'd like to ditch the air pump and EGR, but running without the EGR hooked up will probably give a light. One seller on ebay, "S10Wharehouse", who I didn't buy the engine from claims you can just install the engine and leave the "check engine light" on. Because it's my daughter's truck, I would like to keep the service light working properly.
What I am contemplating, is to use the newer non-EGR intake and connect the EGR valve to the wiring harness, but since the intake has no mount for it, to just leave it tied up. I also want to leave the air pump connected electrically, but disconnect from the exhaust manifolds (and use the newer exhaust manifolds that don't have air pump connections).
Finally, the newer engine has a different style "spider" in the upper plenum. The older style has poppet-style injectors (mounted in the lower plenum) at the end of the lines with the "solenoids" in the center piece. The newer style has the lines running from the center to the individual injectors (also mounted in the lower plenum, but with a shorter recess in the injector hole so you can't interchage the injectors between intakes) at the end of the lines, and the wiring running to each injector. Both styles share the same 12-pin connector at the center connection. Would they both be sequential injection? Is the new style injector cleaner-running, and being at least part of the reason for no EGR?
Somehow, GM did away with EGR on the later engines, and not by the use of VVT (variable valve timing), as used by engines such as N*'s.
Being very up on injectors, I am hoping someone on the board can at least shed some light on this.
Thank you in advance,
Cadillac Pat
Cadillac Pat
