Hey all my tranny has been acting funny as of late and I am not sure what the problem is. I was driving it the other day and decided to have a little fun so I take off normal and let it do the 1-2 shift then roll into it to WOT, reach the top of second and it stays there won't shift to 3rd, hmm weird I say so I let off and it starts engine braking like it is stuck in second. I then give it about half throttle and it takes off normal no slipping but again reaches the top of second and won't shift. So I let off again then lightly get back on the throttle and it kinda "hung up" for a second then slowly shifted into third. Then I gave it enough to force a downshift and the same kinda thing happened it hung up and slowly downshifted to second, then stayed in till I got it up high enough then let off lightly back on and it shifted to third. Now keep in mind this was all done while in D. So then I tried it in OD and instead of not shifting into third I would get the RPM's high enough it seemed like it would just bypass third and go straight to 4th.
Sorry for the book but I am stumped as to what is going on here. Is something up with the shift valves? Anything I can do to fix it or is it time to pull the transmission and have it gone through. There are no other problems it shifts from 1-2 just fine and there is no slipping, when I get on it it will roast the tires not even trying but it just does not want to shift.
