Hey guys,
Sorry.. I haven't had much time to get one here lately!
Seems like we have a couple concerns:
1) Noise
2) Dragging brakes
We put a high friction pad in these systems, we do this because lets be honest... the cars are heavy and FAST. What we have found is for street driving (non aggressive) they make more noise than some would like. This also follows driving style (i.e. people that brake lighter tend to get more noise). Usually noise is found at low speeds right before the end of a stop.
We do have a different street pad, that is a lower friction (MU point), but keep in mind this would not be recommended for racing. The high temps the pad will see causes the pads to break down, and can cause pad taper (which in a small caliper like this) can cause piston cocking/sticking.
So.. with that being said, if the brakes are hung up, first crack the bleeder. Does it retract? If it does this is being held up with hydraulic pressure, check push rod length to master cylinder. If it is something different, like the caliper is froze and pistons will not retract we need to work with you to figure out why. Was the system assembled on modified stock spindles by Baer, or were they hand modified, is the caliper centered, what pads etc.
Please if anybody has an issues, contact me direct at
RickE@baer.com. We are proud of the parts we build, and we want our customers to be happy. We have LOTS of these systems out there, with many happy customers.
Thanks guys!
Rick
