Help cant control boost!!!!
86TType
Slick 86 T-type
I had a ta- 60 on my car that went out so i put my stocker back on and now when i get on it the boost go way up pass 20spi i turn the wastegate all the way out and its still high boost...all my lines are u hooked up any clues?
I may have the same problem according to my idiot light boost guage, having lots of electrical problems also , so it may be affecting the guage. What happens when you run it like that, Does it ping like crazy? Mine does but not sure what;'s going on.Let me know thanks Sno-
Snomachman
The general max turbo pressure for a stock car is 13-14 psi. That sound is called detonation here is a link to help bring you up to speed, and be careful untill you get the problems fixed. It's worth taking the car to a Buick turbo tech. if you need to.
http://www.vortexbuicks-etc.com/
Here to help/learn,
Chuck
