Well, you don't actually "set" the IAC. It is a stepper motor that steps out or in depending on what the commanded idle speed is in the PROM. As long as you're in closed loop, the IAC will adjust the air flow accordingly to control the idle speed. Just as long as the base idle (set by the stop screw) is set properly, the idle will stay consistent. If for some reason the idle doesn't cooperate, you need to look at IAC counts on your scan. That will tell you if the stop screw is correct.
You need to examine the MAF and LV8 values to see if the MAF is the culprit. An out-of-calibration MAF will give you fits when you're dealing with decel enleanment and idle. Have you replaced your O2 sensor? That could play into the fuel ratio.
