SignUp Now!Erson 208/208 hydraulic flat tappet will do just find if you're on a budget. Roller cams are more of a conversation piece than anything.I'm honestly trying to keep the heads stock
I totally disagree. The benefits of roller cams are numerous and well documented.Roller cams are more of a conversation piece than anything.
I totally disagree. The benefits of roller cams are numerous and well documented.[/QUOTE
We can all agree to disagree when it comes to opinions on roller vs flat. Either option will work depending on the application. There are well-known engine builders in this community that have built 9 sec TB running flat-tappet with "0" issues.
Stock heads gonna stud em down... but I'm gonna have to make some changes with a 212 if im.not mistaken??
lots of good input here^^^^^^^My suggestion would be to loose the 3800 converter for a true 2800/3000 stall- 245mm, ditch the 70mm turbo for a 58/60 mm, drop in a small roller cam, over build the fuel system, install an alky kit get it tuned right and turn it way up and hold on... no need for a 9 second. 85lb/min turbo that wont work with the rest of your combo.
We're y'all this tough on me when I first started? Probably... Lol, I deserved it. Roller cams are a huge improvement over a flat tappet. You can grind in faster ramps, more lift, and not have to worry about wiping a lobe with the pressure needed to hold the lifter on the cam. Post up the end goals of the car and we can help. Very knowledgeable guys here.
