Cam help
mrsyclone
Would need help with cam for a GM 4.3l mV6 ( 3.48 stroke) big turbo 88mm A/R 1.08 big boost max rpm 8000...need good spool from 3500 rpm stall rpm apox 5000 rpm! any tips on cam values are gratefully received !Thx
What kind of build?
Why an 8000rpm limit?
what 88 turbo?
this better be a transbrake car
Cause an 88 won't do anything at 3500rpm.
the cam usually dictates the rpm range so if you havent speced one yet
Why...
8000rpm
And why do you feel you need to make power at 3500rpm?
Given your target spool of 3500rpm, you'll likely want an intake duration in the mid-220s range (at .050"). Going too high might sacrifice low-end grunt, while too low won't take full advantage of your big turbo up top.
Thx for ifo ....i need some power from 3500 rpm (to spool)on transbrake up to 5000 rpm and max rpm is 8000
I have on my camshaft today intake duration 242 . i have some problem to spool apox 3500-4000.... after 4000 no problems thx
