I'm neck deep in the rear brakes. I had a wheel cylinder leaking, so I'm changing them out with the S10 cylinders. Got everything apart and was trying to remove the wheel cylinder. There's a part directly above the wheel cylihnder (no idea what it's called). It goes thru the backing plate and has a 22mm nut on it. I thought this had to be removed. It was a VITCH to get loose. As soon as it got loose, it got tight again. Threads were rusted so I oiled them. The "thing" is now half way off and I can't budge it either way.
Does anyone know what "thing" I'm talking about?
What is it? (in case I need to replace the damned thing!!!)
Does it need to come off when replacing wheel cylinders?
