HELP !!!!
I went to have the GN Emission tested. It failed. Went to the DMV. Even though the cashed my check they will not renew my reg. Until the car passes.
Ok it failed two years ago, but they let me reregister it. Here are the readings from two years ago & today
2006 2008
HC - CO – NOx HC - CO - NOx
Limit 132- 0.42 - 921 132 - .042 - 921
Tested 78 - .71 - 802 57 - .02 - 1407
Fail Fail
The difference between this test and two years ago
1. New Cat
2. Replaced PCV hose, because it was collapsing.
3. Regular gas two years ago Vs 93 octane this year
Same chip, Mike Pitts emission chip, fuel pressure set to 40#’s
Now when I went to remove the cover for the EGR valve. After I removed the cover, I found the hose to the EGR disconnected. I do not now if I pulled the hose off removing the cover. But I did press the back of the EGR valve and the engine ran rough but did not stall. Plus I got black soot all over my fingers (must be when I was running the race chip, I could have popped the hose off at the same time.
Now with that said, I did block off the front and rear exhaust cross over when I did the heads. But I can’t remember if I plugged the center holes. I must not have since there is exhaust soot on the EGR valve. I really don’t want to pull the intake.
It looks like it running lean, so I will up the FP from 45 (BLM’s are around 134 now). This should help the NOx?
This is the first time I installed an emissions part and it got worst.
Any ideas, I am running out of time.
2006 2008
Fail Fail
1. New Cat
