TURBOPOWERED68
David
- Jan 31, 2006
Going to do a budget rebuild the target is 11.99 at least once.
The block that I am going to use is an 84-85 block that is what I already have collecting dust in the garage plus it would reduce my down time.
BTW How do these blocks (84-85) hold up?
Back to my rebuild
1-30 over because it needs it -I have a set of used 30 over pistons that I picked up from Cotton’s about a year ago.
Which main bearings should I use (can you please post part #’s)?
Which piston rings should I use?
Do I need a roller cam? For 11.99s and reliable
Or
Would a reg. cam work and last?
The heads will be done after I am done with the Short block so I am not even thinking about them now.
But I would like to get the most I could from the Block because I will be using all of my stock stuff until it brakes or goes bad and I HAVE TO REPLACE IT.
Thanks for the help guys.
David
Back to my rebuild
Or
David
