TURBOPOWERED68
David
- Jan 31, 2006
Charlie just for you
look at what i found in my 2.5 car size shed
the bad news is that i won't be able to do anything with them till i am done with my rear
YEA!!! Now you know where they were at least.:biggrin: Tear them apart and have them cleaned and cracked ASAP David.:smile: I may not get them right away but clean heads are much easier to work on after all.
Preperation H may help you some David.:tongue::biggrin:
That’s funny I’ve had a turbo sitting in the bathroom for about two month now the wife asks me every day at least once when I’ll be taking it back to the garage. Funny thing is I don’t know why I carried it in there in the first place.
I have a bedroom for car parts so I get in trouble if they find them selves in any other part of the house.
Do i NEED steel main caps to run 11.50s reliably on a full weight DD?
the build is going to be
rest of the Combo should look close to this.
1-Roller cam
2-FWD Roller lifters
3-Fully ported OE heads
4-Port matched intake with the EGR stuff gone
5-TT93 Alky chip or Reds Chip
6-60# injectors
7-ALKY
8-Stock headers
9-Dutt Neck IC
10-RJC PP
11-Smallest turbo possible
12-3 inch TH type DP
and all of the supporting mods for my goals
thanks for all your help guys.
Why are you so set on a roller cam?
for my goals of easy 11.50s which roller cam should i get?
Again the car will be a DD with Vacuum assisted brakes.
thanks for your replies and help.
David
All the rumors and stories of "just rebuilt and now a wiped cam" I can not build the same engine twice, well not in the same calender year.
