Nothing can ever be simple with my car
My stock front shocks went out so I decided to upgrade to Bilsteins all around. Part numbers below.
Front shock part # 24-009492
Rear shock part # 24-009294
Everything was smooth and easy, till I got to the passenger side front shock. When screwing in the lower bolts, one of the frame nuts snapped in half, leaving the top threaded half on the bolt. I didn't make it all the way in, so there is enough play to cause future issues.
So now I'm just stuck.
NAPA frame clip nut part # NOE 6501049
NAPA link: https://www.napaonline.com/en/p/NDP6501049
Anyways, I can't for the life of me get the nut off, it just freely spins with the bolt. I could cut the bolt off, but I'm scared that I might nick the shock and fudge its integrity.
I would prefer not to remove any parts surrounding the shock, since doing that means I need to get new bushing. Getting new bushing for just one side isn't really an option so, that means, erthang getting new bushings. And I juuuust don't have the energy for that right now.
Does anyone know of an easy way to remove the broken half of the nut?
To hold the nut in place I've tried screw drivers, pliers, and even putting another nut over it, but I've had no luck.
tl;dr
I broke one of the frame nuts that keeps the lower part of the front shock in place.
Trying to figure out how to remove it, without removing surrounding parts.
There is very limited space.
Thank you for any information, ideas, anyone is willing to give.
tl;dr
