SignUp Now!Bison, so youre saying that this turbo pretty much equates to a 6776? This turbo on my car with the billet 9/11 spooled up quik on a completly stock longblock , stock cam, and 42.5 injectors. Steve V is rebuilding the motor now using mostly stock parts with the 210/215 .516/.516 110 L/S roller cam kit from full throttle. The car already has Alky and all the other supporting mods. Will this turbo be good for this set-up?I'd go with a much smaller turbo. The 6776 has been 9.80's with the late s cover. It won't spool well with mist 3000 stall converters either.
If the wheels are as I see them it will support 9.80's with a purpose built engine. It would take over 9:1 CR, really good flowing heads, 9.5" PTC and a different cam and valvetrain setup. I'd expect 10 teens with boost at 29-30 with decent iron heads on a race gas tune on a 8:1 engine. The turbo will be ok on your setup. It really wants to be in the high 20's boost and 75lbs/min or so flow to make a lot of power before it starts getting tapped out. It takes quite a bit of mods to get that kind of performance though. On a stock longblock it's not even close to ideal. Hard to get over 55lbs/min on a stock cam/head engine. There are a lot of other turbos that are out there that will make more power and not be near the surge line and spool significantly faster than a 6776 on a stock longblock. With the combo your about to run you need to have a flash stall around 5100 and couple by 135mph or you are leaving a lot on the table.Bison, so youre saying that this turbo pretty much equates to a 6776? This turbo on my car with the billet 9/11 spooled up quik on a completly stock longblock , stock cam, and 42.5 injectors. Steve V is rebuilding the motor now using mostly stock parts with the 210/215 .516/.516 110 L/S roller cam kit from full throttle. The car already has Alky and all the other supporting mods. Will this turbo be good for this set-up?
Thanks for the info Bison. I think for the time being im going to stay with this turbo since the car will be barely driven anyways. I am happy we were able to finally identify the turbo. This was one of those deals when you buy a car and you take someone's word for the parts installed and the previos owner never had any info on the turbo.If the wheels are as I see them it will support 9.80's with a purpose built engine. It would take over 9:1 CR, really good flowing heads, 9.5" PTC and a different cam and valvetrain setup. I'd expect 10 teens with boost at 29-30 with decent iron heads on a race gas tune on a 8:1 engine. The turbo will be ok on your setup. It really wants to be in the high 20's boost and 75lbs/min or so flow to make a lot of power before it starts getting tapped out. It takes quite a bit of mods to get that kind of performance though. On a stock longblock it's not even close to ideal. Hard to get over 55lbs/min on a stock cam/head engine. There are a lot of other turbos that are out there that will make more power and not be near the surge line and spool significantly faster than a 6776 on a stock longblock. With the combo your about to run you need to have a flash stall around 5100 and couple by 135mph or you are leaving a lot on the table.
We didn't identify for sure it since you didn't measure the wheels specifically but based on the dimensions I see I'm assuming it is what I stated. Measuring the wheels directly is better for identification. With heads and cam that turbo will be strong between 5000 and 5700@27-28 psi.Thanks for the info Bison. I think for the time being im going to stay with this turbo since the car will be barely driven anyways. I am happy we were able to finally identify the turbo. This was one of those deals when you buy a car and you take someone's word for the parts installed and the previos owner never had any info on the turbo.
