Help! Lots of General ???'s
Jaycat
The too slow black hole
Well, you can see what's on my car now. I'd just like some opinions on where to go next. I know I need a bigger downpipe, which is best and where's a good place to buy. Also, what kind of intercoolers are people using. Do those power-strokes fit up front? Is there something more effient? How far can I go without changing fuel injectors? Any answers would help greatly! Thxs.
Forget the front mount on your car. A stretch stock location would be the best. Injectors are cheap and easy to install. DO EM! 3rd page on my link has the stretch intercooler to view.
Timing chain and valve springs if not done already.
Scan tool
Adjustable fuel pressure regulator
Walbro 340 fuel pump
Fuel pressure gauge/boost gauge/knock gauge or alarm
Turn up boost slowly, watch for knock.
This gets you into the 12s and can be done for less than $500.
Next is tires.
Don't worry about a bigger turbo, injectors or IC until you are well into the 12s and want to get into the 11s AND spend a significant amount of money.
SCAN TOOL!!!
Adjustable FPR then possibly Alky with a good chip.
The only other thing I could suggest would be a 3" DP prefrebla a Houston or ATR 1 piece.
