Need some advice on cutting my 60' times down by at least 2-3 tenths from the best of 1.9x. The car has the following suspension/brake items:
s-10 brake pads and wheel cylinders
h&r lowers
h&r motor mounts
air bags on both springs
I also run full 10" slicks and fronts on weld racing wheels.
I have played with the car extensively and can only hold about 3 pounds of boost on the vacuum brakes. I have also adjusted the rear brakes in an attempt to hold more boost but it just doesn't seem to want to hold anymore. I don't want to waste money throwing parts at the car so what are some opinions on where to start or what to upgrade. I have also played with the airbags and they really don't seem to make any difference.
As a comparison, my GN with the powermaster would hold 5-7 lbs of boost and consistently cut 1.7x times with a bone stock suspension.
h&r lowers
h&r motor mounts
