heres the scoop.
going to the track next saturday, the 25th.
im borrowing some nitto DR's.
filling up with 114 octane.
i have a known problem with the timing jumping up a tad after
it is suposto be lower for higher RPM, so i cant run as much boost or timing as most people can w/ 114 octane.
what do you think i will be faster with, more boost or more timing?
im thinking its going to come down to either 19 PSI w/ highr timing or 21 PSI with lower timing.
this is the stock turbo.
with my combo, on the Nitto DRs, do you think i can hit 12's like this?
here is my combo: stock turbo, stock intercooler.
3 inch stainless down pipe, LT1 valve springs, 009 injectors, all the fuel system mods, MAF translator plus, extender chip, K&N filter on end of MAF.
rear suspension mods consist of KYB shocks, stock springs and pinion snubber.
PS: i have a dump i can open, but the car feels like it has more torque through the muffs.
