http://www.engraver1.com/help/ecm.gif
On pin a6 it shows key on voltage to be 12.3 my key on voltage was 12.07 - 12.11
The same chart also shows an open circuit reading to be 12.15.
So do I have a bad ground on the ign / ecm circuit?
Thought the module grounded through the bracket.
All of the computer grounds are under the a/c compressor correct?
Anyways getting interesting.
Thanks,
Jerry
I really don't think you have a voltage issue, at least not the kind you are thinking.
Sure, battery voltage could be higher, but at idle, the car should not be doing what it does. The voltage drop you are/have - seeing/measured are somewhat normal.
If you truly had a "misfire" due to low voltage, the O2 would read the oxygen, and "think" the car is running lean, and add fuel (Increase BLM)
So in your case, the opposite is true.
Also, don't like the "0% DC" you are seeing on decel. That tells me that there are some more serious issues.
What that means is that the ECM is shutting the injectors off, because something is telling it to do so.
I will look at the file tonight and need to think about that one.
Here is a good pic of the ECM pin-out. Wire colors may be differenct, but it is close, until the ignition module . . . . .
http://www.gnttype.org/techarea/ecmsensors/ecm3.PDF
Have you tried another injector harness?
Put a test bulb on #4 and see what happens while you crank it, or run it (idle)
One more thing after looking at the wiring; Is the oil pressure switch connected?
