USMC_Turbo6
- Dec 13, 2009
My dad it looking to upgrade from a TA-6676 P/trim journal bearing .63 a.r. housing ported wasegate hole.  What would be the best turbo for him to go with?
SignUp Now!My dad it looking to upgrade from a TA-6676 P/trim journal bearing .63 a.r. housing ported wasegate hole. What would be the best turbo for him to go with?
Since he's looking for more than we can assume he is running nearly 135 mph trap speeds. Posting the rest of the combo would help. Especially the torque converter.My dad it looking to upgrade from a TA-6676 P/trim journal bearing .63 a.r. housing ported wasegate hole. What would be the best turbo for him to go with?
His mods are 109 block girdle, 1-3 billet main caps, stock rods, je piston, GN1 head ported with matching intake, 62mm TB, 55lbs inj, ls1 MAF, FMIC, 218/218 flat tap cam, scan Master, 1.5 roller rockers, red double pumper and a TE45 with a 63 housing
He want to run low 10 and the converter is a 2800 L/U
ok cool, looking at what I have in my sig would that get into the mid to low 10. I have a 3200 l/u what more do you think I would need.
ok I also have a set of 3.73 gear in the car too, So what would be the best converter for the steet and strip?
So with what I said and wanting to be able to drive my car any where the 3200 n/l would be the best for the street and strip. What about my dad cause he wants to update his turbo from the te45 to something better and he has a 2800 l/u
