3.8L V-8 eater
- Jul 22, 2006
Hi, to all
I have had my car apart for sometime. I put in a fresh built tranny and 2800 stall converter. The trans I put in has a TR valve body, but the casing was changed out to a what I believe might be a 700 series. I was told it was universal could work on Cutlas, Monte, Regal, Tr Regal etc.
My problem is after fighting with the dipstick tube I finally got it in and the bracket fastened to the top of the casing. Now the dipstick won't seat flush with the dip stick tube
... Could this be because of the different casing??? The stick is itleast a full inch from the top of the tube plus the stick has a recess of close to an inch that goes over the tube. I flipped the stick around backwards "no dice"
Any help here would be appreciated!!
Thanks!!
Tony
Thanks!!
Tony
