Help please. Runnin Pig rich
darkred87T
I recently put new heads and cam on my car and when I got it back and running I noticed the car is running super rich as soon as it kicks over. Sometimes it's hard to start if it sits for a while. I had a plain old Extender chip in it with my 60# injectors. I hooked up the T-Pro there was no change. My WB02's hang around 10:1 in open loop.
So far I checked the cam sensor position, replaced a suspected stuck injector, checked all my settings and verified that the IAT sensor was functiioning and that FP was where it should be. I'm using speed density with the T-pro but like I stated before, I was having this problem before I installed the T-Pro.
When the car warms up, the ECM struggles to keep the idle@14.7:1 but really it's all over the place and it's constantly hunting in closed loop.
Thanks in advance for any suggestions
No, I don't know how to flow check them. I do have another used set I can try though.
