Help plz
GN GURU
Don't worry honey this one is the last one
WHen I turn on my lights (head lights) I lose my dash lights, rpm led cluster back ground even the ones around the radio & gear indicated plz help me this sucks
Sounds like a bad switch, can you turn the parking lites on first then turn headlites on and parking lites go out??
Head lites & park lite go on fine it's the in side lite I lose
Have you adjusted the interior lights brightness knob? It could be turned off. It's that knob next to the light switch.
You have a short. It is probably the wire for the bulb of the indicator light under your console. This wire almost always is the culprit. The constant shifting breaks the wire and shorts to the metal bracket of the shifter. Remove the console and fix the wire and replace the blown fuse and you will be good to go.
