snomachman
- Apr 9, 2006
Found a hole in line going to actuator for turbo (overlooked this one could not see it) the other line goes to the intercooler after turbo. They are both connected to a Y fitting and then go to the left side of sensor on top of the valve cover.There is also a nipple sticking out on the right side of sensor that looks like a hose is suppose to go on it. Is this suppose to be a bleed off? Trying to find more info an turbo and wastegate.
Took car for a ride and still running to much boost. Does this wastegate actuator work off vacuum or pressure? (sry little knowledge of turbo, you can tell right this is my first car that had one)
So let me know what you think ? thks Sno-
Looking at Vortex right now. Thanks
