Tom Tom Turbo
Turbo Goes Woo Woo
- Jul 10, 2002
I seem to be chasing my tail with this issue. My SG1 block build is causing some headache because the front cover seal near the oil pump location keeps leaking. However, it will only leak after boost has been introduced. I can replace the gasket, let the car idle for 30 minutes, or even drive it around very gingerly and it won't leak, but at the first hint of boost, it starts leaking.
The PCV valve is a new GM one and I've tried others that don't seem to have an effect. I went with larger open element breathers and that seems to considerably reduce the leak. Last night I did a compression test to make sure it wasn't a bad ring or something that didn't seat properly. My readings came back 131, 134, 140, 136, 138, 143, which all seem to be within the normal range.
I've had the aftermarket HV front cover at the machine shop and they indicate that it is flat and not warped. What are the odds that my block is jacked up? Any other suggestions?
