help with cam sensor install
1987noblegn
I'm sure someone has asked this before. I'm having troubles pushing cam sensor all the way down. I've been trying to turn crank to get slot for oil pump gear lined up but I am still struggling. Any ideas?
Dont turn the crank ,make sure your at 25 degrees atdc then use a long screwdriver to turn the pump gear to 11 oclock postion t,hen hold the cam sensor with the screw holes at 9/3 oclock.then take the window of the sensor with, cap off and turn it to 5 oclock. not a great typer!!!
give me a call 941 416 7509 and i would be happy to walk u threw the steps , make sure you have a cam sensor toll!!!
JD
