help with small trans part.and a question
cutluse231
I have a 82 Regal with a Buick 455 in it backed by a 200R4, w a GN 8.5 rear with a 3.42 Posi. rolling with 275/60/15's on stock GN wheels.
First there is a small pin that goes thru the trans gear drive piece that the quill from the speedo cable goes in and the speedo gear rides on..... I need that piece my speedo cable froze and sheared the quill inside the pin, I cant get the quill out... so I need a replacement pin.
The question is..... with the combo listed,what gear can i swap too on the end of that pin to make my speedo accurate.. I think mine is blue, it is a GN 200R4 trans.
again thanks ahead of time :)
According to my GM g-body speedo gear chart and tciauto.com's calculator
your tires are 28.00" tall and if a 200-4r is a MW9 transmission, then you need
a "D" 12T red drive gear GM#8634935 and a "V" 29T green driven gear GM#
25524924. Please verify that these are the right gears as they are not cheap!
call me up at the shop tomorrow .the right gear set is 69.00 with pan gasket and governor gasket
Chris thanks for the response, I did trying calling the NY # today got no answer.
Is there another number?
Again thanks :)
Again thanks :)
Leave a message. He will call back. He's very busy sometimes.
