I have what I believe to be some valvetrain noise that's setting off the knock sensor above 5600 rpm.  I have a 210/215 hydraulic roller cam and GN1's with adjustable Scorpion roller rockers.  I borrowed a valve spring checker from a friend but there's no way it will check them in the car.  I had recently set the valves at 3/4 past zero preload.  How I did this was I backed off the rocker arm, then tightened it down while spinning the push rod in my fingers.  I assumed zero was when I couldn't move the push rod with my fingertips.  I've read a couple of posts with similar combo's where it was recommended to go to 1 full turn or .050".  I'd like other opinions to confirm or deny this.  Also I've been reading the info that came with the cam and I'd like to check everything else that could cause noise I can without pulling the intake or heads such as:
-Push rod length ok?
-Push rod to guide plate clearance? What should this be and could this cause noise?
-Do I have the correct valve springs? How can I tell?
-Rocker arm to head, stud, valve spring retainer clearances?
D
D
