I have a loud noise from the driver side of the motor. sounds like a knock at idle but increases with rpms. all pistons and rockers/arms are moving the same when valve cover was removed. Noise seemed to be narrowed down to the driver side cylinder closest to the fire wall with the mechanic stethoscope, however with spark plug wire off the noise remained. The springs look ok, motor is stock with 53k. I am out of my relm if it is in the low end of the motor.....
any suggestions?Ideas?
