Chris Gullett
- Oct 20, 2014
I am hoping someone on here can help me with a problem with my 87 GN. The car starts fine, idles fine and drives fine for about 45mins or until it is fully warmed up. Then it starts to have a hesitation or starts missing. Most of the time this happens around 2000 rpm, sometimes right from idle. At 60 mph you can feel a steady miss. The blms at 60 mph are low, about 105. Then the miss/hesitation will go away for a few minutes.
The car is bone stock, 20k miles. It has been in storage for the last 20 years. So far I have done the following:
O2 = moves from 0 to 700 (approx)
AF = 5
LB = 39
Bat = 13.5
INT = 130
BL = 122
TPS = .36
IAC = 19
CC = moving, but on occasion moving slowly
I tested the old coil and it was open on 2 of the packs, the 3rd was at 12,000. The new one tested 11,000 on all three. I thought this or the ICM was the issue. It seems I was wrong. The MAF passes a tap test. Any help would be appreciated.
- Gas tank flushed and new fuel pump installed
- New fuel filter
- Oil & filter
- Air filter
- Replaced coil and control module (Delco stuff from nos4gn)
- spark plugs and wires
AF = 5
LB = 39
Bat = 13.5
INT = 130
BL = 122
TPS = .36
IAC = 19
