Bruce, I didn't want to hijack the other thread, but this is worth talking about...
(Following is taken rom here...)
What you probably don't know is that the load axis is programmable, just like the RPM axis. If you are running a 3-bar sensor, and want the last 4 rows of your table to function between 25 and 28 PSI, just put numbers between 25 and 28 in the last 4 rows. The resolution is only dependent on the A/D that is reading the sensor voltage.The Accel VII sure is lacking as far as table size goes in my opinion, by the time you crank it up for 3 bar applications there are way too few steps in the fuel table.
A DFI on the same engine would kick the crap out of that car. Literally, you'd be able to tune multiple 10ths off the time. We just did it with our LS1 kit. Replace the stock PCM, retune with the DFI, and ET .3 - .5 seconds quicker with NO OTHER Modifications. Here is one example, there are more than just this.I seriously doubt you could get the fueling as good as Steve has with the latest ME's.
update...beta test 346 cam/heads car
base line before install : 11.5 avg, 117mph
this past saturday : 11.06@122 with a 3.73 gear 28 tall tire ..Car never made a good sticking pass,was observing atleast two revolutions before it left the line..definately has 10.8 or better with traction .Geared properly 10.6's are possible..and to think this car has a pro fogger sitting on top that we havnt gotten to yet
Joe Overton
" The underdog "
94' Trans Am -388 ci. Lt1
9.86@134.5 1.35 60 ft. (All motor,footbrake)
