hey can sumbody answer my question
ejaygn
ejay
If you put a roller cam in your gn can you use your stock rockers or do you have to go with the roller rockers? Let me kno please
The stock rockers aren't as strong as roller ones and with the higher spring pressures that roller cams use, roller rockers are a good idea.
You can use stock but not rec'd. You will need to verify pushrod length
hey thanks guys i was told the setup i have in my motor which is bored .30 over,stock crank.stock rods,diamond pistons .30,port and polished head,with a roller cam should bring me in the 10s or so...
