dr_frankenstein
Mad Scientist
- Mar 17, 2008
If you took the original boost level and added 30% (flow increase) that give you rough power at stock power level. Roughly 245 HP at 8 PSI. Now what's the formula for each PSI equals how much HP?
thats is if you assume that boost and power rise in a linear fashion....
they do not in our application. Heat/foot negate that.
you cannot devise that "X" amount of boost will result "X" amount of horspower. Without even being close to the choke point, the boost power ratio becomes quite skewed throughout the rpm range with the movement of air through the housing. The housing doesnt flow the same amount for the given pressure depending on where the point is at that particular moment for mass flow. Poor flow, fuel drop out, distribution and puddling are all of these variables. Not to mention the added battle of the rising heat as the boost increases which has it own effects on the density of the fuel/air charge and how the rise in temps effect those parameters.
later GNs point that this was an issue that engineers fought with and why they canned moving fuel through the turbo along with the style of foot. the later HA cars arent much different then our setup if you play the math.... cause the intake was very simular in thought, and biggest difference being point of fuel introduction and the elimination of the foot.
ive held onto this info for a long time now.
