Just installed 50 Lbs Injector along with PTE Chip. New Fuel Regulator is set to 43 PSI. My BLM's are constantly at 150 during Idle and will go down at cruise.
Tearing my hair out looking for vacuum leaks and quick inspection on the Driver Side headers for leaks.
Car had normal readings prior to the injectors/New Chip and Fuel Regulator.
Can the Chip from PTE cause the problem?
Also, can a leak near the boost/vacuum gauge cause the high BLM's?
Thanks in advance.
Thanks in advance.
