HighMileage
Albany,NY
- Jul 24, 2010
Hey gang.. I'm getting high BLM's in most of the cells. Idle is 142. I have checked for vac leaks.
Sometimes chips are set up to be a little on the high side? I notice no Closed Loop at idle,too. No Learning,either.
Is there a good place I can go to and read-up? I've searched. Nothing seems to go in-depth.
When I had the new turbo and alky installed by a known name here,he put a different chip in that he said matches what I have. It sure would be nice to know exactly what I have.
This winter I will be installing a higher stall converter,so I'll need a different chip?
Thanks.
Thanks.
