high block learn bad injectors??????
chops
I checked for leaks I found nothing replaced lower intake gasket anyway I have 50pnd injectors I think 1 of them are dumping to much fuel that would explain the sputtering on take off any ideas ????
Too much fuel would create an overly rich condition, this would cause LOW BLM's as the ECM tries to reduce fueling.
HIGH BLM's are usually caused by a vacuum leak (could be anywhere), or a pre turbo exhaust leak.
