I was running a decent size cam its in the sig.. I also thought t was way rich igniting unburnt fuel,, i leaned it out quite a bit and did not see more than 30 degree drop in temps
Tim,
Thanks for the reply.
I agree with the above. #1 is low timing. Coupled with a very rich AFR it may be igniting unburned fuel in the exhaust.
Does the turbo spool abnormally well?
Don't think 25deg timing is "low" on 93 and alky.
Spool is ok.
+1...........with your set-up, you're on the verge of making alot of HP.....
...........................as a wise man once told me.....you've got alot of tuning ahead of you..........good luck :biggrin:
Dwayne,
Care to share who that wise man is?
Seems a bit rich with the alcohol. My car only runs about 1600 degrees with the probe in the down pipe for reading on a quarter mile run. I usually only see about 800 on the street on very hot days. Otherwise around 600-700 and goes up if I get into the boost. I don't think I've ever seen egr readings that high on my set up. Interesting.
The probe is mounted right before the NB sensor, in the header.
This is where I thought you needed it, as close to the exhaust port as possible.
Regarding AFR;
My uderstanding is that most run in the 10.7-11.0 AFR range with alky (780-790 mV), so I am not sure it is rich ........... But I have been wrong before. :frown:
This car actually likes 10.8-10.9 with alky.
could this have anything to do with the tt chip you had made for you that keeps the afr constant?
Everything must be questioned at this point.
The chip has AFR target adjustments for Mid and WOT.
Mid range is running leaner and higher timing, so I am not sure.
From experience, it will be one of the last things I will look at since the PL is indicating timing and AFR.
I talked to few people and I have some "theories" :tongue: on this high EGT. :tongue:
1 - Caspers no longer sells the probe (ungrounded)
2 - The EGT amplifier from FT should be OK.
3 - The WB sensor is new.
4 - The ignition timing was verified.
5 - The plugs are new (Old ones looked OK)
EGT indicates 1571F @ 800 rpm, 13.5 AFR, 16.5 Deg timing
