SignUp Now!Add number 4 "bad thing" with these POS covers:
4) Front seal must be retained with screws or whatever, as they do pop out.
Be VERY careful with aftermarket timing covers. I have had more than 70% of them BAD. Here are the things to watch for, in my experience.
1) Oil passages COMPLETELY blocked
2) Cam sensor to oil pump alignment problems. They machine them at different angles. Check this BEFORE you spend any time on the timing cover. Slide the oil pump drive gear (long one) into the cover, then slide a cam sensor into the top. Watch the two interface. It should slide in with no interference. (remove the o-ring on the sensor to make it easier)
3) Gear cavity way too deep to get a thrust clearance of .002" or less. I've had the gears sit flush with the cover. Add a .007-.009"" gasket, and that is your thrust clearance. (BAD!!!) You have to machine the cover down, to get the gears to stick out of the cover aprox. .006", then shim the filter adaptor to net you .001"-.0015" thrust. It is very hard to get the clerances just right. It will take you 3-4 hours of fiddling/grinding to get a timing cover set-up just right. And that is if you are good at it.
One would think that it would take quite a bit of blow by for that to happen. I've used aftermarket covers before but never had that problem.
We have used them before too, and only lately have we had this problem.
One was a 9 sec. GN running about 23-25 psi boost, and the other a 10.0 car not over 20 psi.
Fortunately TA is machining a front cover for V-6's that will be "matched" to the original Buick blueprints [except for the external oil seal because that is the way they are now being cast.]. We are discussing a way to accomplish seal retention, and also a "racing blueprinted" option, both complete and bare.
The machining tolerances will be much closer than even the original factory covers.
One serious problem that is being corrected is the cavity clearances for the pump side clearance. This MUST be done right the first time, or it will never give proper flow or pressure. After TA examined many China and Taiwan covers, this varied from bad to horrible.
Not sure of the pricing at this time, but it will be more than the off-shore machined junk, and close to what GM was selling their original cover.
Knowone has posted yet how to tell the differance between the orriginal & aftermarket front covers!
This would be some usefull information to people who bought a car and isn't sure whats on it..
I had an aftermarket one on my old cars engine and had to find out the hard way that it was junk and leaking like hell. After trying to fix it twice I ended up installing my old stock one and never had a problem after that. At that time I never really looked at them both to see if there was a differance..
Scot W.
Scot W.
The cover I got from DLS does not leak even when maxing out the boost to the TSM legal limit .
Yeah but thats just 24.99999 lbs. What about us guys who want to turn it up a little more than that?:biggrin:
My DLS cover dry as a bone
Felpro makes a seal which can be installed inside the factory cover. In order to install this seal one must knock the flanged lip out of the factory cover which retains the fabric seal.
I just got 2 old GM covers & 2 sets of the Felpro gaskets. So I need to knock the lip out of them? Any further details please? Didnt know that altho I havent looked at them really its all in the "Pile to Do" area. Thanks!
Nick,
...... The person I talked to on the phone said that the plain cover I bought from them is the same one they use in their $450 setup and they haven't had any complaints. That's not to say it doesn't need some work, however.
Thanks, Jim
