87we410877
- Apr 5, 2005
what is involved in putting a high volume oil pump from ATR in? from start to finish.
SignUp Now!frankg said:Why do you want to install a HV set?? No that it's totally bad but why? Frank
buickpower said:ATR just sells the Melling kit. It's a hell of a lot easier to do correctly when the timing cover is off, like John said. If you don't take it off, you will have to at least jack up the
Thanks alot. Im a fan of doing things the correct way. Must have something to do with being an aircraft mechanic. I will take the timing case off and get that sucker in there. thanks again.
87we410877 said:[
Red Regal T said:If I were you, I'd pull down the oil pan and have a look at your bearings. Sounds like they may be toast. It's just as easy to change out the main and rod bearings as R&R the timing cover and oil pump.
87we410877 said:I hope thats not the case. The motor was just built in Mayland and only has 3200 miles on it. My timing case is modified, i dont know if that would effect the oil pressure. Its also bored .030 over and has cast iron heads with bigger valves and a cam. And also which plate are you talking about that might be worn. thanks alot.
