turbonut85
Rarely used member
- Apr 11, 2008
Alright fellas....here's another newbe question... I just converted the 85 to run on E-85. :biggrin: Got the 60lb inj and chip from TT. All the supporting mods are there...i.e.: fuel pump, hotwire, scanmaster, ported heads, intake, etc. etc....so, the question is: How do I crank the boost up past 15 psi? Will the stock WG handle more than 15 psi?? (threaded for adjustability, of course) I bottomed out the rod and can only pull 14-15 psi. Is there a HD wastegate actuator available for the H/A cars? I know some people are using the 86-87 actuators....but I refuse to tear up the new hoodliner on my 85...is there another option?? Manual boost controller?? ...how do they work?? Do they work in conjunction with the stock WG actuator? Any help is greatly appreciated. I would sure like to get the boost up into the sweet spot of this turbo....(kinda bigger than a TA33C....) ---Keith
