Not sure what you mean by "sticky rears".
Bleeding the brakes is a relatively simple job that alot of people mess up. Try doing it again. Do it the old fashioned way, as you've already done and push the brake pedal down slowly while someone else cracks the bleeder (or you crack the bleeder while someone else pushes the brake pedal). Don't "pump" the brakes. I have speed bleeders on the rear and that makes the rears a one man job at least.
I heard you clamp the proportioning valve plunger when pressure bleeding the fronts, not the rears.
Did you use "used" parts? Are you sure they're good? If the brakes don't feel hard and they work, I'd assume the booster is fine. The master cylinder may not be though.
Are the rubber hoses to the front calipers and the one central rubber hose in rear in good shape?
I assume there are no external leaks anywhere.
As you've done, it's a good idea to expand the rear shoes as far out as possible so the drum barely fits over them. For my car, I needed the drums cut to true them up to get the final stopping power I needed (thanks TurboJim). What I'm saying is that the condition of your drums is something else to consider.
The way I see it, the fronts "could" be bad and that may affect how the rears hold...and vice versa. A defect anywhere in the system could affect the whole system.
Good luck. I went through a few headaches when I converted to vacuum brakes too. I bleed the brakes 3 or 4 times, changed the MC twice, replaced the wheel cylinders, adjusted the rear shoes and cut the drums; all to get good braking. I can now hold ~8psi with street tires and can lock them up in a panic stop (not necessarily a good thing, but at least I know they work to their maximum potential). Haven't been to the track since the conversion so I don't know how well my QTPs will hold.
