Here are some pictures of the intake for my twin turbo Buick Stage 2 engine project.
This is a modified carburetor Manifold. Kendall Frederick started the conversion, and I added the extra injector bungs and fuel rails.
With a goal of 1000 whp, the required injectors would be too big for any kind of low speed running. Hence, 2 sets of 6 - 85lb injectors, the second set coming into operation at a certain rpm/boost as controlled by my Electromotive TEC3r.
This setup will be fed by two Aeromotive Eliminator fuel pumps pulling from separate fuel cells with 1/2" hard lines up to the fuel rails- the secondary cell will contain race gas for street use, race gas in both for high boost track use.
I'll use the TEC3r's GPO outputs to control pump speed via PWM through homebrewed power drivers.
That's a 1550 cfm progressively linked 2-barrel Throttle Body- I'll probably have to replace the carb hat's inlet tubes with bigger ones but will wait and see after the whole thing is flowed with the heads.
Now, If the machine shop will EVER get done with the motor, I've got the top ready to go - Just needs to be powder coated.
