TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Now have single AND double hood mount gauge brackets in stock. Powder coated steel set up for use with Autometer 2 1/16" #2204 gauge mounting cups. They have nut rivets installed so you don't have to struggle with wrenches while installing the gauge cups. Fits the contour of the hood nicely and screws to the flat surface under the hood. Holes are already drilled in the brackets for an easy installation. Not cheap but not cheaply made either.
Perfect for a fuel pressure gauge and you can use a double mount if you want to add a boost gauge next to it.
Made in the USA.
Click below to go to my site.
Hood Mount Gauge Brackets
Made in the USA.
